reevesy
hi all,
going round and round in a world of media and music streamers and i've come to the conclusion i'm probably best off sorting the storage out,ripping music and films ( could continue to use my xbox as a stop gap.....aware of compatible file issues) and when budget allows get the player side of things sorted.
.....dont know if this is the best way to go
....music is a toss up between the usual suspects sonos or squeezebox (and the software needed to run it).
.....films maybe the med8er.
...basically squeezebox aside i'm just after a good storage system for film and music in one room only with something i can stick in the cupboard and only be on when i need it.....would have to be quiet though. portable storage would mean another box on the shelf and not out the way.
the nas side of things i thought would be reasonable straight forward until i started to read about stuttering with the squeezebox label art side of things and the basic operating system of a nas being a problem....though this would be a problem with a sonos as i understand it.
budget at the moment is about 250 to 300 quid...cheaper the better though.
the nas side of things ....been looking at things like the
the netgears....duo and the stora
...also seen the free hard drive offers.
or do i put together a cheap very basic pc second hard complete or secondhand build it yourself (never done it but have upgrade mine a couple of times with bits and pieces) and add acouple of hard drives along the way...then just run it when i need it....probably a couple of hours at the time.
..connection would be wired most likely and would all ahve to be reasonable simple to use...as others might be invovled in the music playback side of things.
would generally like some guidence folks as my time spent doing my online reasearch is starting to stretch it a bit with the family
any help with making some sort of decision would be graetly appreciated.
cheers.
cheers.
