On a 4:3 ? settings for widescreen film.
Discussion in 'General TV Discussions Forum' started by swayzak, Nov 27, 2001.
  1. swayzak
    swayzak
    Nov 18, 2001
    253
    +3
    please excuse the rather noddy question:
    I 've just bought my first dvd player (pioneer 444) but have a 4:3 tv.
    Do most people watch widescreen films with the dvd set at 16:9 (with complete, but vertically stretched, picture) or 4:3 (with a more marked "letterbox" effect) ?
    I know this probably depends on personal taste but is there a generally accepted setup ?
    cheers
    swayzak
  2. Doubledoom
    Doubledoom
    The 16:9 mode on the dvd player is meant for widescreen televisions or 4:3 televisions with a 16:9 mode.
    You are not meant to view 16:9 on a 4:3 set in 4:3 mode!!!
    So, you have to decide to watch it either as 4:3 Letterbox or 16:9 and press the 16:9 button on your tv. If you cannot tell the difference in the picture quality, then stick with 4:3 letterbox.
  3. swayzak
    swayzak
    Nov 18, 2001
    253
    +3
    My tv's a 6 year old Panasonic - so 4:3 mode it is then !
    Is 4:3 pan 'n'scan better than normal 4:3 mode.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    In most cases it won't make any difference.
    The Pan&Scan mode is there for those 16x9 DVDs (which are few in number) which have a special Pan&Scan code added to them. This enables the player to pan&scan the (wider 16x9) image on the DVD and output it as a full screen 4:3 image ie cropping the left and right edges to make it fit.
    As for whether it's better - if you prefer to see only part of the picture yes (although, as I say - it only works on very few 16x9 DVDs)
    If you prefer to see the whole picture, reduced in height, with black bands top and bottom - then no.
