Omnimount
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by jamesgrahamuk, Jan 10, 2005.
  1. jamesgrahamuk
    jamesgrahamuk
    I'm looking to support an Eltax Symphony centre speaker above my projection screen.
    The Omnimount speaker brackets would seem to do the job, both aesthetically and practically - allowing me to angle the speaker down towards the seating position and have it 'floating' from the wall with no nasty clamps, shelves or brackets in sight.
    However, I can find no supplier which stocks anything above the Omnimount 10.0 wall bracket. I'm pretty certain that the symphony centre weighs more than 10lbs. Looking at Omnimount's website I see that they do a 20lb and 30lb version of this bracket but, as I say, I can find no UK supplier.
    Does anyone have any suggestions?
    For reference, here is a link to the 10lb version at hifistore.co.uk:
    http://www.hifistore.co.uk/product.php?qsProd=OM10WALL
