OmniMount speaker brackets
Discussion in 'Home Cinema Speakers' started by Glenn Keen, Mar 28, 2006.
  1. Glenn Keen
    Glenn Keen
    Apr 30, 2004
    159
    Roos, Nr. Hull
    +8
  2. 1 GND
    1 GND
    Jan 25, 2004
    185
    +8
    Probably too late now ...but use these exact mounts with my M&K 55MKIII Tripoles and work great. Only problem I found is that it`s quite tricky getting around back of speaker to tighten up the desired postion.
    Hope helps...
  3. Glenn Keen
    Glenn Keen
    Apr 30, 2004
    159
    Roos, Nr. Hull
    +8
    Thanks for the reply.
    As it happens there was a change in plan of where I was going to put my set-up, new room only stud walls so I ended up opting for stands insted of wall mounting them.
    Cheers for the reply though.
  4. 1 GND
    1 GND
    Jan 25, 2004
    185
    +8
    No worries and always happy to help another Glen(n) as we`re a rare breed !!
