Omnimount 23" to 62 Wall-mounting Starter Kit
Urien Rheged
Normal Price £40.00.
Was only £10.00 today at my local Tesco store.
http://m.tesco.com/mt/www.tesco.com...l-mounting-black/215-8763.prd?un_jtt_redirect
Description
This Omnimount flat panel TV wall-mounting starter kit gives you everything you need to help you mount your TV. With this flat panel starter set, you will be able to mount anything from a 23" to 62" TV set. The Omnimount TV mount kit allows you to mount, clean and connect televisions of all types, including plasma, LCD and LED TVs, and from 100x100 up to 400x400 Vesa fittings, or up to 68kg. You can connect up your TV and tidy away unsightly cables with the cable management system that is provided with the kit. Once mounted, you can tilt your TV on the mount to avoid glare from the sun, or angle your TV downwards if you have got it high up your wall.
The flat panel TV wall-mounting starter kit comes with a 1.4 version HDMI cable that is 1.8m long and is Full HD compatible.
The cable management can be painted to blend in with your room.
The cleaning gel is non-drip and free of both alcohol and amonia.
