OMG - Vinyl Rocks!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by warrj, Nov 8, 2004.
  1. warrj
    warrj
    Well, I had a very interesting experience at the weekend. My father's cheapo midi system has died recently so I offered to give him some of my 'retired' components; a Creek 4040s2 integrated amp, Genexxa hybrid speakers, old Technics CDP and old Technics tape deck. I went round at the weekend and wired it all up. I also connected my father's old Bush turntable - a very cheap marginally hi-fi piece from the mid-nineties. We then went thru each source in turn checking that it all worked OK.
    I was absolutely gobsmacked when we got to the turntable. He put on an early sixties LP called 'Music From The Greek Islands'. Wow! It was so, for want of a better word, musical. It sounded more musical than my hi-fi at home (Krell integrated, Arcam CD23 + B&W 805s). Damn.
    So, it has occurred to me that I actually have a turntable lying around at home. It's a Dual from the late eighties/early nineties which a friend gave me when he emigrated. I've never even opened the box...
    Assuming that I'd like to give the Dual a whirl I'm guessing that I'd need a phono stage of some sort. So, what would people recommend as a 'starter' phono stage? I assume that the valve-based ones are hideously expensive? Are they worthwhile?
    Regards,
    Jules.
  2. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    Vinyl has a lot going for it still :)
    Budget - NAD/Rotel/Project £40 up - OK sound wise - a step up from most budget integrated amp onboards (if they even have one)
    MF XLPS £150 used about £100 (has a valve stage) - pretty good and a definate improvement over any of the amps up to £1k I have used.
    Trichord Dino / MF V3 / Graham Slee £1 - 300
    Above this I reckon you need a better deck along the lines of - Michell/Rega/Nottingham/Roksan with decent cartridge
    Very pleased with my Dino and it can be upgraded with a NC PSU - this type of PSU made a large improvement to my Gyrodec
    Check what cart you have as some stages only do MM and poss high output MC and not the normal MC's
    Gus
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,536
    Manchester suburbs...
    +142
    don't forget the project Tube Box - valve based phono stage with an amazong sound for £300!
  4. SKA.face
    SKA.face
    Creek OBH are truly superb for thier very small price,go well with the Rega decks,moving up a bit,there is the Lehmann black cube SE,the Graham slee,Dynavector P75,and the Sonneteer sedly to consider,but the Creek like the little amp you have a stunning.
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    A little shout for Moths 30 Phono stage : £275 new and can be picked up for a lot less secondhand. TE Microgroove can be had for a shade over £350 as well.
    As for the joys of TTs Ive bought a couple of Project Debuts for friends who did not want to spend a fortune on a TT and they sound stunning to these ears VFM wise, in fact I dont think I would have a £300 CDP before a Project Debut. OPMMV of course. Anyway good to see someone finding cheap vinyl playback can sound real hifi wise.
