S
sberemski
I had to disconnect my AV setup a fiew days ago and upon reconnecting it, the plasma did not seem to work. I then check the leads and it turns out that the cable from the Plasma media box(the one with all the connections on it) which leads to the plasma was not plugged in fully. After plugging it in an image appeared on the screen.
After a bit of flashing on the screen the normal display appeared but it was green and had lots of noise ( or "snow"). This green appears on all the input channels and on the PC input. I dont kwo what to do. I think the plasma is broken.....
ANY ideas would be welcome.
