Omg My Loewe Aconda Has Blown Up
Discussion in 'General TV Discussions Forum' started by richduc, Sep 5, 2003.
  1. richduc
    richduc
    Got up this morning turned telly on, picture for 1 second then off, buzzing niose, smell of burning components!!! Coud not turn on again so switched off from mains. Sounds terminal. Any ideas?? This telly is less than 4 years old (one of the first in the country) - tellys should last longer, no?
  2. davej
    davej
    Jul 31, 2003
    85
    Sunderland
    Last time I had a TV do anything like that it turned out to be just the on-off button burning out, a fairly quick and cheap repair job - and quite a common one on a lot of sets according to the engineer, so I wouldn't give up all hope just yet.
  3. Piya
    Piya
    Feb 6, 2002
    Leeds
    My Grundig Xantia 32" just had a similar symptom - when last switched on it made strange noise for 5 sec then died. Now it's in the repair shop costing me £160 to repair!
    The engineer says something to do with power regulator and line output. I only got this tv for less than 2 years and paid £850 for it.
    Can't beleive a German tv is of this poor components.
    Piya
