Olympus C765. Indoor Theatre pics
Discussion in 'Photography Forums' started by hansi, Aug 21, 2005.
  1. hansi
    hansi
    Aug 15, 2004
    270
    Cardiff
    What is the best setting to take pictures of the stage in a dark theatre? I have taken some but they are out of focus. Can't seem to get the flash settings right either. :lease:
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Well, i'm surprised they let you use flash. I doubt your in flash range? You need to open up the aperture to it's widest (smallest F number) and bang up the ISO to get a shutter speed good enough to stop motion blur (i take it you're shooting people on stage) even slight movement will make your shots look out of focus if you've not got enough shutter speed. Forget the flash, the inbuilt one's not going to cut it.
    But the light may well be that poor that it's beyond what your camera is capable off. You're going to get noise when you increase the ISO but it's better then missing the shot.
  3. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    how far from the stage are you?
  4. hansi
    hansi
    Aug 15, 2004
    270
    Cardiff
    back stalls, but I can use the full zoom
  5. MattB1
    MattB1
    As Seany says, you are probably trying to push the camera beyond it's capabilities. At full zoom on that camera an average person would need to get a shutter speed of 1/380th of a second. In anything but very good light you just haven't got a chance.
    If you were closer and didn't need to zoom then it'd be a bit easier.
  6. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    Unfortunately low light focusing is the only real drawback of the 765
  7. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    The aperture's not constant on the 765 i'm guessing, which makes it even harder. If that's the case, your only hope is to get close, leave it at the wide angle end with aperture at it's widest (2.8 i think) with a high ISO.
  8. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    Your right there seany, the lens is f/2.8-f/3.7.
    The only way I was able to get low light shots with the 765 was to get close and bump up the ISO... Unfortunately it still seemed to struggle, so getting focus was still hit and miss, not to mention the extra noise that goes with the high ISO.
    Another idea would be to stick it on a tripod/monopod if you have one which will help keep it steady and might help it get focus lock, though I'm not sure how much this would actually help.
    Regards,
    Iain.
  9. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    my 750 olympus used to struggle a bit, took an age to focus and then more often than not it wasnt in focus!
    used to be able to get some good shots but it was more technique than anything
  10. MattB1
    MattB1
    It's not impossible - it really depends on the amount of light coming from the stage, the ISO and timing. Here are a couple i've taken in low light with the 765 at long or full zoom. Not great but better than no photo's at all.
    Low light pics
    As far as focusing goes try to lock focus on an are where there is a contrast such as between 2 colours or a horizontal or vertical line.
  11. sorbiegunner
    sorbiegunner
    Jan 16, 2004
    184
    Try manual focus on a couple of shots, with magnification of the focus area in the viewfinder.
