Olympus C-310
Discussion in 'Photography Forums' started by mevetts, Jan 11, 2005.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    I am after a starter digital camera and this one seems to fit the bill. Under £100 and I'm only going to be storing the pictures electronically so the MP count should be fine. However, just wanted to know -
    1. It takes an xD memory card. Are there different types of memory card and where is the best place to buy memory cards?
    2. A number of reviews say the camera eats batteries. I would want to get some rechargables, but are there 'better' rechargables i.e. they last a lot longer, than others. Again where is the best place to buy?
    Many thanks,
    Mark.
  2. Zone
    Zone
    Jun 24, 2001
    6,754
    Barnsley
    +2,459
    This at Steve’s Digicams should answer your question on memory cards.
    I have no experience with this particular camera but I can see why they say it “eats batteries” as it only uses 2 AA, personally I’d go for something that uses 4AA but leaving that to one side, go for good quality Ni-MH rechargeable batteries 2300 mAH and higher.
    Oh and you'll need a good charger, ie fast 30mins to an hour for a full charge.
    Loads of places Online personally I use places like pic-stop.
  3. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks Si,
    Much appreciated.
    Regards,
    Mark.
