yep Olympic section in the epg genre and 24 channels now showing on my panny tv, however just the genre section showing on the humax overnight update will put that right.
Who on Freesat can see the BBC Olympic channels?
no need, got home yesterday and it was fine.
It appears that the Echostar updates these things when in standby, and the deep standby is better for this than the Sling ready standby.
Interestingly though it you go to the football or opening ceremony, they are not showing the HD or DD+ sympbols, likke they are on BBC1HD. The when there is no programming the channels say BBC Olympics 17 HD, suggesting that they are HD channels.
Anyone else confirm?
Are the SD channels coming across to the EPG? I can see them on my Humax HDR in non-freesat mode but only the HD ones on the freesat EPG.
I can't record anything at all yet in HD but I can record the SD streams in non-freesat mode. Ch13 has been showing a live stream of the "torch cam".
@GLT
Even if I did record the programme I am not sure how I could tell if it was HD. For example when running Red button services (inc iplayer and multiscreen) from an HD channel the Echostar still lights the HD and DD+ lights on the box at the bottom, even though red button is not that quality (but the programme that lauched it is)
REPASSAC said:The SD channels are hidden on HD STB's.
The recording problem on preview streams is known - all is expected to be normal on live events.
Good idea, as the HD channels are simulcast of SD channels but in HD quality, not sure why any one who had HD would want to view any SD channel, so what would be the point of putting both in EPG (which What happens on a Sky box for some puzzling reason)
I was asking to see if you can create a short recording that you can play back. Currently on a Foxsat-hdr you can't record the stream.
This morning I set my Foxsat-HDR to record Olympic channel 1 HD (151) from the EPG (Women's footie at 15.50). Box woke up at the right time and seemed to be indicating a recording in progress according to the on-screen icon. However, when I went to cancel the recording it told me that recodings of less than 30 seconds might not be saved. Sure enough, the progress bar on the recording had not moved even though it had been running for 20 mins. Nothing was saved. Even a manual recording (pressing the Record button) didn't record anything although it looked to be in progress.
what about the HD part?
I am looking at channel 152, it seems to be SD.
Channel 153 is showing nothing, but the EPG for that entry is BBC Olympics 4 HD. Both channels lack the HD part in the channel name, but programme names include the HD when not showing anything.
Even though I upgraded my HDD to 1TB a couple of years ago recording in HD will soon use up all my spare space.
I'm off to reinstall raydon's firmware plus the new channel editor - may give me some extra flexibility to record red button streams
(I had uninstalled it a couple of months ago due to problems with recording Neighbours and Home and Away on CH5 - ergo low WAF). I think I've convinced 'er indoors that this is entirely due to crap EPG issues with CH5 and that it's nothing to do with the firmware..... I hope.
No idea how to find that out on the Echostar.What transponder is your 152 on, you may have the SD stream instead of the HD one. A short recording of 152 is HD on my Foxsat
The SD streams record fine by the way.
All it can tell me is:
Network ID:59
TransportID:2022
Service ID 7803
BBC Olympic 2
any help?
