Olympic weights needed for multigym, what do you recommend?
Discussion in 'Health & Fitness' started by Luckys3, Aug 14, 2013.
  1. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
    Can anyone recommend some decent Olympic weights with 2" diameter for a multigym.
    Any deals to be had on the uk mail-order sites, ideally I would like a 125kg set to start off with, I've seen some tri weights that look half decent, but would prefer them to be in black if at all possible but they only seem to be available in silver.
    Any thoughts on some half decent weights?
  2. njdbaxter
    njdbaxter
    Feb 13, 2008
    3,803
    103
    +365
  3. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
    Thank you for the link, do you know if the inner diameter is 2"? how bad were the blemishes or are they very minor which would occur from a days usage anyway.
    I just checked the details and unfortunately they're 1"
  4. Ruperts slippers
    Ruperts slippers
    Dec 18, 2004
    8,202
    Earth
    +4,182
    Nah they're 2 inch Olympic plates, I used to throw my plates about so they end up chipped anyway...
  5. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
    Your absolutely right, I didn't read the details properly, they seem pretty good value for the kg.
  6. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
  7. reiteration
    reiteration
    Mar 21, 2012
    10,200
    +8,904
    just buy the cheapest you can find, look on ebay and gumtree - there maybe some 2nd hand ones...
    afterall, you're gonna lift them, and not look at them? :)
  8. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
  9. MTech535
    MTech535
    Aug 27, 2012
    445
    +32
    Do you already have a bar and collars then?
  10. Luckys3
    Luckys3
    Jul 21, 2009
    1,134
    48
    Surrey
    +71
    A friend of mine has a spare olympic size bar that he is throwing my way.
