Oled65wPla vibration on sound bar
Discussion in 'LG TVs Forum' started by killersjp, Jan 14, 2019.
Tags:
  1. killersjp
    killersjp
    Jul 16, 2008
    83
    +7
    Hi everyone. Just had a LG OLED65W8 installed. The picture is great. The sound bar however does make a vibrating noise with the bass of some songs. Only on about 30 in the volume selection. I think it’s the resonance of the base sound making the plastic casing vibrate making a hum. Anyone else notice this?? Thanks.
