I am before buy and testing an LG 55EG920V UHD 3D tv in the store.
I switched off every picture improvements that the tv has so all setting off or minimal
I photographed two things one is 4K pattern which should shows white line between the coloured lines.
You can't see white between the green lines properly. Is it normal for 4k oled? I clearly can see it on my monitor and my Sony 4K LCD tv.
Also surprisingly can't see all blue lines. The horizontal bottom and vertical left should be all blue but they are black. Why?
You can see other pattern shows the blue properly also there is no lack of blue on photos or movies
The other thing is the 3D left right eye pattern. those photographed through the 3D glass. I can't see this effect on movies just if the scene very dark. But this pattern clearly shows what visible to the other eye that should not. Is it normal for 4K oled?
The photos are here
https://photos.google.com/share/AF1...?key=U0JmZ0E1UEY1ZkpOQTY1d0REdjRzY3JETy1xUEdR
The photos are here
