DB9506
Established Member
Onto my 2nd 910 and whilst there is some vignetting there is minimum banding and tint. So that's good and I could probably live with it, but......
The screen seems to flicker when watching via the aerial input. The last 910 didn't do this.
The screen image seems to only do it when the scene changes quickly. It's as if the image on screen cannot keep up with the software going on behind the image.
Has anyone any experience of this and the likely cause? As said the previous set did not do this so it is set specific. Faulty hardware or software?
Any informed advice/insight into the cause appreciated. The set is a good one but for this damb flicker.
It only does it when watching via aerial input. Faulty tuner? Big job to change it?
