MovieHound
Folks: I am new to the forum but I have reviewed several threads on this subject, yet I still am not sure I understand it all correctly. It seems to me that Yamaha has made their system more complex than it has to be, but that just could be me. My system is a very basic 5.1 setup. Here is my issue:
When I select a show from one of the streaming services, on the display of the receiver I either get "straight" or one of sound field programs such as "drama" (also cinema dsp is visible on the display).
There are limited options when in the "straight" mode--cannot select a sound field program or change the surround decode. The receiver displays "not available" when pushing those buttons on the remote. However, all my speakers are visible on the display and sound is coming from all the speakers and voice audio, for example, is clearly coming from the center speaker. So I assume that the system is running in surround mode. Correct?
Alternately, on a different show, the system defaults to one of the sound field programs like "drama" and the "cinema DSP" icon is visible on the display along with all the speakers. In this situation I can use the remote and change the sound field program and/or select a different surround decode and customize each sound field program. I conclude under this scenario that the incoming audio signal could not be reproduced in surround sound unless the receiver used the internal surround decode features. Correct?
Am I correct in understanding that the receiver when it sees a legitimate 5.1 signal, passes the signal through without additional processing ie "straight"?
Alternately, when the system does not recognize the audio track, it will use its internal surround decoder to simulate surround. Correct?
Therefore, "straight" surround sound is "true" unmanipulated surround audio.
Thanks in advance to all those respond.
