This is yet another thread about bass management. More specifically about bass management on an older Denon X4300H.
I have searched this for quite a while, and sometimes I end up in the owners thread. Seems like I can never get the bass settings just right on my receiver, and I am starting to suspect there might be issues with the processor..
Equipment:
Receiver - Denon X4300H (7 years old)
Front - B&W 702 S2
Center - B&W HTM71 S2
Rear - B&W 686 S2 (from a previous build)
Subs - 2 x SVS PB-2000 pro (gain -15 with room gain compensation for 25Hz, 6dB slope)
I use umik and REW for measurements, and the measurements look OK with a house curve. I have also purchased the MultEQ App, and is using that to tweak the Audyssey room correction. Subs are time aligned together with MiniDSP, and time aligned with center channel on crossover currently at 80Hz. I have tried 60/80/100/110 but 80Hz feels like a safe "middle ground" at the moment. Dynamic EQ and Volume is currently off, as I find the boosting does not sound good, and I do not want boosting of rear channels.
AVR trim for front speakers set to 0.0 by Audyssey, and subwoofers measured together as one set to trim -4.5. I have bumped this up by 6-7dB together with the MultEQ house curve config. All speakers set to small. Never used LFE+Main. The Room Gain Compensation lowers a troublesome peak below 40Hz.
As far as I can tell, the LFE channel (0.1 channel) performs like it should, and effects that are specifically put there by sound engineers seem to excite the subs. When streaming content from Netflix, the master volume is often somewhere between -15 and -20. My issue is with the bass content that should have been sent to either of the other channels (e.g. gunshots in John Wick). If I play some music (Spotify Connect directly on receiver, master volume -40), the subs are barely playing anything at all. It feels like the bass management processing of my receiver is "off", as in not accurate or not added to LFE channel correctly. Note the difference in master volume level from Spotify Connect (-40) to Netflix(-15). I can't see any reason for this difference..
I did a microprocessor reset recently which didn't fix my issues, and have been playing around with settings trying to fix this for a very long time now.
Any tips, tricks, or experiences from anyone dealing with bass management on their denon appreciated.
Equipment:
Front - B&W 702 S2
