Older Arcam as a preamp into my (Upgraded) Naim Nap 200 power amp?
abmscopes
Don't go too far back into Arcam pre-amp-world; their 1990's pre-amp sections suffered from seriously crackly input selectors; something that cleaning the pot. only ever resolves for a few months.
enjdee
True - the Alpha and Delta ranges were brilliant, but the selector issue was a pain - I used to have an Alpha 9 amp, which I loved but let down by what must have been one cheap component.
Again, the FMJ AV8 or 9 are technically more sophisticated, but fewer mechanical components and less to go wrong - and built like a tank too!
enjdee
Oh, and if you really want the Arcam sound, as a future upgrade you could flog your Naim, and replace it with an FMJ power amp.
I had both the P25 and P35. Personally I preferred the P25 (and I had a very, very rare black one), which I felt had a more robust, solid sound and a build to match - the P35 seemed to have a less solid build (rapping your knuckles on the front plate and the casing is a good test!), and also had a transformer sensitive to noisy mains. To be fair, I haven't heard that's a common problem though, so either would be a great choice.
A perfect visual match with the AV9 was the icing on the cake!
sparkymarky
Sorted :)
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
