I know about that.
I automated the thumbnails using my movies and got them all automatically.
the problem is having them displayed
I have renamed them the jpg's to folder and they are in the DVD folder containing the VOB files.
However PS3MS only displays the ISO folder and not the art...
Sorry you didn't mention before you were using ISO's (not many do as PS3 is rubbish at ISO's, even with ps3ms)
Pretty sure PS3MS doesn't support coverart with ISO's yet...
Thanks for the amazingly fast reply. Yes I could install PS3mediaserver (ON ONE PC) but the media is all on the WHS / NAS as there is way too much to hold on the PC. So if a version of PS3mediaserver was available for a server as opposed to a pC then i could try. I could try anyway on the PC and see if it solves the problem on a sample of the tracks.
But any clues as to why, if PS3 supports AVI out of the box it does not work? I plan to post these questions also to the WHS community and direct to Sony tech support.
If I get any sensible answers I will post them
As i said then, try PS3 Media Server![]()
I have recently bought a NAS drive and most files stream fine.
But I have noticed some files on the NAS don't seem to show on the PS3 (yet the PS3 would play them direct from INT HD or EXT HD).
These include M2TS files (from PlayTV), some AVIs (Not all!) any ideas? I presumed any files that would play from the HD would stream fine (or is that not the case?)
Sounds like maybe the NAS DLNA software doesn't support those file extensions. Is it running an OEM DLNA app or a generic one like Twonky? if it's Twonky try an upgrade to a new version or if not Twonky give that a go....
Its an old Synology NAS DS-106 , I bought it off Ebay a few months back, so it must be using the Synology software, its fully up to date, but no new firmware for the last few years.
I think (will check) its playing some AVIs but not other AVIs, they work fine over NAS to Netbook etc.
I don't want to fiddle too much with the setup, but from what you are saying can I add my own software to the NAS?
Is there anyway to use a web browser interface (or purpose written app) from a PC to access the PS3 main menu system to control playback? I'm use the PS3 Media Server for music duties as well as films, but I don't want to turn on my projector just to control audio playback. And no, I don't have a PSP.
Just started using the media guide as i was having difficulty putting Hi Res files on a FAT32 Ex HD works a treat quick question streaming a 10gb 1080p file stutters over a wireless network which is understandable going to get some homeplugs me thinks.
Anyway to my question i decided to copy a 10gb 1080P file onto my PS3 HD wireless from my pc and its still going and its saying 13gb copied over but the file is only 10gb anyone???????
