Quantcast
old tv with sky+
buns
I have been using a good panasonic tv with my sky+ connected by scart without an issue. Tonight ive had to go back to an old tosh tv and connected the same way, I get no sound through scart. I can get sound by connecting an audio lead..... but I dont understand why..... anyone any ideas?
ad
Starburst
TV volume not turned up, believe me I've had a head scratching session with that problem in the past:)
Have you tried a different scart cable and/or tried a different device on the TV scart to confirm that the socket is ok.
Giving the cable a wiggle doesn't do any harm either.
buns
no no, def have the volume turned up..... can vaguely hear the audio from channel 1 in the background! The scarts I have both worked with my panasonic tv so there isnt a problem with scart leads or the sky+ box..... was just wondering if there was a setting somewhere that i could have missed..... might have another go at wiggling mind you..... with an old tv and loosish scart, it sounds like the most scientific approach :D
ad
