Old TV RF Socket Coaxial Connection
Discussion in 'General TV Discussions Forum' started by abz_da_man, Jan 12, 2005.
  1. abz_da_man
    abz_da_man
    HI having an old tv, i only have an RF socket, would it be possible to connect somehow a coaxial cable (Ie the screw in type with thin wire sticking out) to the rf socket?? The reason for this is i want to connect my dvd player to an rf modulator, and the rf mods, Output tf socket is actually a coaxial output socket, and i want to connect this to my actual rf socket in my tv, thanks....
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    (If I understand this correctly) You need a cable with an F-type plug on one end and a TV Plug on the other. You can easily put either type onto a bit of coax cable so acquire either a). One standard TV-Video lead (male-female), snip the female connector off and replace with an F-Type satellite plug or b). Snip an F-type plug off what you already have and put a male TV plug on the end. Or you could acquire an F->TV plug adapter and use the cable you alread have.
    HTH,
    Mike.
  3. abz_da_man
    abz_da_man
    any ideas where these can be found and if they actually work??
  4. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    Have a look at the ARD Electronics website.
    Mike.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,439
    Somewhere in South Yorkshire
    +5,851
    .....or Maplin
