old tv 3 scarts new 2 scarts how to connect it all up please
Discussion in 'Cables & Switches' started by mick23, Dec 19, 2006.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hello all old tv has 3 scarts fed as follows
    sc1=satellite box
    sc2 =dvd recorder
    sc3=sky digibox
    this all works fine,but new lcd tv only has 2 scarts so making things akward.
    i believe there is a way off linking sattellite box to digibox to dvd recorder using scart leads and feeding a single scart to the rgb scart of tv.
    but i am not sure of how to connect this all up, or if there is a simpler way.
    to record onto dvd at present i use recorder set to ch1-5 for terestial recordings.
    sc setting for sky sc2 for satelite.
    do not really want one of those multiple scart boxes /
    new tv will be 32" technovision lcd.
    kit i wish to connect is
    pace sky digibox
    tatung dvd recorder
    humax 5400 satelite reciever
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    It would REALLY help if you told us exactly what you have, Make model etc. Can the DVD player do Component and better still Progressive.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks andy have edited my post with kit deatails.
    the dvd recorder has component/composite connections and progressive scan.
    thank you
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    Sky via Scart (Quality) set to output RGB not PAL and 16:9 not 4:3.
    DVD via component if your TV has it and progressive even better.
    Humax if your other SCART on the TV is RGB then make sure it outputs RGB.
  5. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
    What details do you have on the LCD, i.e. where is it coming from
