Quantcast
Question Old Tannoy Sub Issue. Advice Needed
nipbiplip
Hello all.
I have an old Tannoy TFX sub that I was hoping to bring out of retirement for a secondary cinema set up.
Problem is, upon plugging in, there's no sound not even a low hum.
The red light comes on in 'off and Auto' position, but switching to On there's no green light.
I've tried it with 2 av amps, changed the internal fuse with no joy.
And ideas I could try before I have to shell out for a replacement?
Gasp3621
Sounds like you have tried everything. Unless you know any electrician i doubt there is not much to do, as it has some serious amp related problem. It has served you for many years, some people aren`t that lucky with these cheap subwoofers. Fixing that would cost over 100£ and that is not wise as you can get new much better one for 200£ home delivered!
So i would look in to new one and the best part is you get an upgrade how your total system sounds when you get something better sounding / performing!
Get BK sub with 2year warranty and great customer service / parts availability! This will bring new life in to your satellite system for sure! Upgrade in performance and build quality is from another planet. I would also add wife friendly looks. From experience i can say, money is well spent here!
BK Gemini II Subwoofer in Black 5060403220004 | eBay
BK Gemini II Subwoofer in Light Oak 5060403220059 | eBay
BK Gemini II Subwoofer in White 5060403220035 | eBay
nipbiplip
Thanks for the reply.
Yep, I feared as much to be honest.
I have a BK XLS200DF in my primary set up and I agree they are a lovely sub.
Funds dictate, however, that I won't be replacing the tannoy with another BK anytime soon so I better get saving!
shotokan101
Probably worth unplugging from the mains and taking the plate amp off just to check if there are any loose/disconnected wires or blown components
nipbiplip
Cheers. I will try that, although I'm not that good with a soldering iron! But defo worth a look
Similar threads
