Old sub problem
nolia
I have a old eltax ea sw20 sub and when I plug it or unplug it from mains it makes a kinda explosion sound. sometimes it doesn't do that.why is that? apart from that it works well.
Member 639844
Former Advertiser
Its picking up a sudden mains surge when you plug it in. You should really have the sub turned off on its amp on the rear of the sub before plugging and unplugging. Once plugged in, you can then turn it on and it should make that sound.
nolia
even when its turned of at rear... when i turn it on at the rear switch it does the same. maybe a ground isolater can help?
Aerial Man
My sub momentarily makes a noise when you turn it on, it's nothing that will damage it. Be carefull not to plug the power lead in when the switch is in the on position, or plug the subwoofer cable in when the subwoofer is on.
Nothing can really hurt it apart from electronic surge, so use a protector for all of your kit.
nolia
the odd thing is I have a 8 plug surge extension connected to my TV,PS3. xbox,sub,sat-box. I would have thought that will help
Aerial Man
So do I but the sub still makes a loud pop noise when turned on and off at the back. It always has from new and it's only really had 1 years worth of use. I have never thought much of it, my guitar amp does the same thing.
I find the best way is just to leave the sub switched on and turn all the tv stuff on together at the switch. No noises that way
nolia
I don't know what to do. On the other hand it kinda makes u jump when u turn it on or off. It is a instictive reaction. will check for ground isolaters. the other sub doesn't even do that.
Member 96948
Most subs use a relay on the poweramp outputs to prevent the switch on thump as the poweramps supply charges and settles down. It's a cheap sub, so it probably doesn't have them and there's nothing that can be done about it unless you stop turning it on or off.
It's not damaging it, that's the main thing.
Russell
smk
Try turning the volume down to it's lowest setting before switching on or off. Give it a few seconds and then raise the volume.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
