Old Sky remote on Sky+
Discussion in 'Sky Digital TV Forum' started by maverick177uk, May 1, 2005.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,786
    103
    +485
    Is there any way of using your old sky remote on Sky+, so it can be used in another room?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I haven't tried this myself, but....
    Press select+blue together, then "2" for Sky+
    Press select+blue together, then "0" for normal Sky.
    No idea whether this works on Sky remotes or just Sky+. Good luck ! :)
  3. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,786
    103
    +485
    Cheers will try :thumbsup:
  4. acanning
    acanning
    Mar 11, 2002
    109
    16
    Hampshire
    I tried on an old Sky remote with a Sky+160 box. It sort of works in that the channel + and - buttons work but no other buttons work at all.
  5. Cynthia 7
    Cynthia 7
    Hi maverick,
    Looking at the http://www.satcure.co.uk/tech/digicode.htm site it mentions that changing the Sky remote for Sky+ usage will only allow it to change the channel + and - buttons as mentioned by acanning. Sorry.
