You sure on the model number? I can only find the SG-F111?Hi. Speakers definitely work but no sound coming from right hand one. Tried two different speakers that work and nothing. Any suggestions please? Diolch-Cheers , Daf
they should just be standard glass fuse type.. usually around 20mm x 5mm .. IF... the unit is fitted with them.Cheers-yes it's the 111 s sorry! Will have a look. Can I source them easily?
hmm... it would appear this unit does not have speaker fuses judging by the photo... this possibly could be the amp module itself on the output may have shot...Hi. Not very good with electrics so posted a pic. Set it up at the moment with an adapter through an aux code to my Bose speaker and the good news is the record player’s working! Could you possibly point out which fuses they are as I haven’t a clue sorry! Cheers. Daf
