Old remote will control Sky+
Discussion in 'Sky Digital TV Forum' started by mariosambucci, Nov 28, 2003.
  1. mariosambucci
    mariosambucci
    Now this is dead easy.
    Press T.V and release
    press and hold down SELECT and the BLUE button simulttaneously, until the L.E.D. blinks twice and release. Press#2 and release.
    Press SELECT again and release.
    Now your old remote will control the basic functions of your sky+ machine from R.F 2 out.
    Hope this helps some of you out there.
    Mario:hiya:
  2. gossp
    gossp
    Nov 5, 2002
    388
    Lincolnshire
    +7
    Hi mariosambucci, brillent tip.
    Is there a way of putting it back to normal sky control after you have made these changes? Or will it still work for normal operation after having made this change?
  3. mariosambucci
    mariosambucci
    To return it to normal sky control. press tv, then press red button and select together until the l.e.d. blinks twice, the press 999 this wipes all the memory from the remote control and will work normal sky digi boxes. You cannot control both systems at the same time.
  4. gossp
    gossp
    Nov 5, 2002
    388
    Lincolnshire
    +7
    Excellent.
    Very useful for me now I can use my spare handset.
    Thanks again
  5. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Mario - im guessing that this only operates the channel +/- buttons or does it give you more control than that?
    Steve
