Old PS3 question - component HD out
Discussion in 'Playstation Forums' started by Mackle, May 9, 2016.
  1. Mackle
    Mackle
    Mar 20, 2007
    324
    Finchley
    +15
    If I was to use a component out rather than HDMI out on a PS3, will the lack of HDCP authentication cause any issues for gaming, so would it just be Blu Ray and TV catchup that would be affected by it?
    I'm currently using an auto-switching HDMI switcher due to lack of HDMI ports on my TV, and everytime the PS3 does one of it's resolution switching things that it likes to do, the HDMI switch gets confused and switches over to something else. The PS3 is only used for playing some games that I'm yet to finish / play through, it's not used for catchup or Blu Ray, so was thinking that component would resolve the HDMI switch getting confused.
  2. Nakatsu_Hime
    Nakatsu_Hime
    Nov 8, 2009
    502
    UK / Hong Kong
    +72
    You could use an HDMI to SCART convertor if you wished, and all that would happen with you gaming is it would get more fuzzy.
  3. Mackle
    Mackle
    Mar 20, 2007
    324
    Finchley
    +15
    But if I used a component, I'd still be able to get 720P whereas I couldn't through SCART.
  4. Nakatsu_Hime
    Nakatsu_Hime
    Nov 8, 2009
    502
    UK / Hong Kong
    +72
    Indeed, but my point was that the resolution your TV ends up recieving will not impact anything gameplay-related, other than resolution, and perhaps a tiny tiny bit of input-lag, introduced by the convertor.
  5. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,844
    +1,187
    I have been using Component on my PS3 for the last few years and not had any issues in gaming. And you also get the same picture quality via component as you do via HDMI on the PS3 (not the case on the 360 though, the picture quality is considerably poorer via component than HDMI on that).
    You can even set it so you get 1080p via component on the PS3.
    I do not watch Blu-Ray via my PS3 though.
    But do use it for Netflix, NowTV, Hulu and Iplayer and not noticed any issues.
  6. illogicology
    illogicology
    Oct 30, 2009
    Games all play fine through Component at 720p on my PS3. I use it regularly for capturing gameplay vids.
