Old PC, What OS and Photoshop!
bouncer
Joined
Dec 27, 2005
Messages
3,672
Reaction score
284
Points
905
Location
Glasgow
Well ive got a old Dell GX150 kicking about that I actully plan to use, hardly but plan to use it,
Tis a Pentium III 1Ghz, with 256MB Ram
So I need advice, What OS and I need Photoshop on it so what version of photoshpo and I think thats it
Thanks in advance
Win98 is about the best you can do, 2K would probably install but 256Mb RAM is going to be a problem with image editing whatever and 2K will use more real memory and you don't really want to be swapping more than you need.
Why Photoshop? Unless you really need it then maybe Gimp or an old version of Paintshop Pro would be a better choice.
It's going to be a grind no matter which way you go, while this is a 'spare' system I question how useful it will be unless you're only needing to do 'trivial' image processing, in which case Photoshop is way over the top.
Only planing on using it as my laptop is off getting fixed! Same box with same stuff is running Windows XP just fine-ish (Buit for step dad to use ebay)
But Windows 98 SE seems like a good idea, What photoshop can run on this?
I have 7 8 9 and 10
(As far as im aware 8 is CS 9 is CS2 and CS3 would be 10?)
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
