Old or New
Discussion in 'AV Receivers & Amplifiers' started by makum, Dec 8, 2004.
  1. makum
    makum
    Hi I'm on the verge of buying a new home cinema amp the denon 3805 is high on the list however I have noticed the pioneer ax3 is now on offer for £499, is the denon really worth an extra £400 ! :confused:
    Does anyone have an alternative
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,519
    London
    +1,005
    It really depends on what features you're looking for. If you don't need Denon link (i-link) then the Denon 3805 is probably not worth the extra money imo. But it also depends on how power hungry your speakers are.
    The AX3 is a good amp, however there are a lot of newer amps at the same price (or even cheaper) which would probably have the same if not more features.
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Look at the Marantz 7500 too... ;-)
