Old NEC Plasma, connection help needed!!
Discussion in 'Plasma TVs Forum' started by Budge, Oct 21, 2004.
  1. Budge
    Budge
    Jul 29, 2002
    366
    Leics.
    +6
    Hi all,
    I'm currently in possesion of an old NEC PX-42VP1G Plasma Screen.
    It's been used to show some promo display in a store, so there's a bit of screen burn, and the brightness/contrast seem quite low, but i've got an option to buy it reasonably cheaply (mostly as a second, bedroom display).
    Anyway, before I get my wallet out, I need to make sure I can get an RGB signal into it, from an RGB SCART output. (Several sources thru a switchbox).
    The specs of the model I have are here:
    http://www.nec.co.jp/press/en/9909/3001-01.html
    Im currently using the s-video socket, and the picture is reasonable, considering the screens age. I just need to know if I can utilise one of the 3 various RGB inputs:
    1) 15pin D plug. I presume this is a VGA connection? (Excuse my stupidity if i'm wrong..)
    2) 5 BNCs (R, G, B, H/CS, V). Can I use this lead from Keene http://www.keene.co.uk/cgi-bin/codesearch.pl?SBB42 to connect to this?
    3) DVI 29 Pin Digital. I have NO idea what this is for, never seen a plug like this before.
    Any advice would be greatly appreciated, even if it's to tell me not to touch it with a bargepole!!
    (P.S: One of my DVD players, as well as my Xbox & Gamecube can produce a progressive scan output. Is this screen compatible? I dont think so, as there doesnt appear to be a component input?)
    Thanks in advance!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Budge
    Budge
    Jul 29, 2002
    366
    Leics.
    +6
    It's £130 though...
    Hoping to do it on the cheeep (I'm hoping the screens only gonna cost me about 2 or 3x that...) :)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
