Preacher
Many moons ago I had Sky TV which I cancelled when I bought a Humax Freesat 1000S, the HDD failed on my Humax so I was unable to record anything, so I got Sky again, (18 months ago) new dish, and new satellite coax cables . I have cancelled Sky again and swapped out the HDD in my Humax to see if I could record with a different HDD. I fired up the Humax and at first I was getting a strong signal through one cable, sat input 1 and nothing on sat input 2 I swapped the cables around so then I was getting a strong signal on input 2 and nothing on input 1 but either way it wasn't strong enough to get a signal. I switched to non freesat mode did a scan and got loads of channels. I did a factory reset and now am getting no signal on either input so I cant scan for channels in the freesat mode.
I guess my questions are, have Sky done something to their dishes so you can't use them anymore with freesat boxes ? could it be the F plugs they use aren't compatible with the Humax ? the coax cables aren't strong enough to give a signal to the Humax ? or is my Humax just stuffed ? I was a going to buy a 1Tb freesat box but if Sky have scuppered their equipment to only be used with their Sky Q boxes then I guess I wont bother.
Or should I just get my tin foil hat
