Quantcast
Old catalogue widescreen con
topmba
Some older movies have been edited on DVD, as Widescreen Anamorphic.
However this is done by cropping the 4:3 version.:confused: bottom quarter.
I noticed this as I upgraded some titles from VHS to DVD.
Eg. Dirty Rotten Scroundrels, starring Michael Cane and Steve Martin.
I wish they had edited them as 4:3 and let me zoom in Cinema mode if I wish to.
Garrett
They did something similar to the original The Time Machine but the was in made in 1.66 : 1 so it is not as noticeable.
inzaman
They must do this with a few older movies as i know robocop was changed to 1.78, and evil dead was also changed. Thankfully i have the dvd versions with the proper aspect ratios of both though.
Garrett
I have just looked at specs for the movie which was Aspect ratio 1.37 : 1 (negative ratio) 1.85 : 1 (intended ratio).
They do something worse which is a bugbear with me is they shoot in 16:9 and cut to 2.35:1.
Kevo
:confused: Huh
Surely these are films made in open matte where the intended ratio is say 1.85:1 yet 'opened up', i.e the borders are removed for TV to give a near 4:3 ratio.
4:3 is NOT the intended ratio and sometimes you can see too much space above the actor's head and also see boom mics appear.
Be rest assured that the WS version is the correct version you are seeing and how the Director intended it and not the TV stations.
Garrett, surely you already knew this?
figrin_dan
You would then lose a hell of a lot of definition. If a subtitled film was like this you could lose them too.
Garrett
Kevo are you referring to my first comment or second????????????????
The first I’m only stating fact.
If you mean the second I have heard that explanation before, so how come a lot of the shoots cut the top of the actors head off in 2.35:1.
I saw Starship Troopers in 4:3 and cannot remember a boom or mike in site. And there was more area shown top and bottom in that version than the 1.85:9 version so even that must have been cropped.
Kevo
I'm sure this topic has been discussed on several other occaisions and usually in favour of the WS versions!
The correct/intended aspect ratio is the WS theatrical version and is always the one I prefer to the 'TV version'.
I'm not saying you see the mics in all these films, but you can notice them on some of them.
Don't forget, with Super 35 open matte you do get more width. Any extra height is a 'bonus'.
A lot of films are shot this way these days and have been since the early 80s when home video took off.
Have a look here for a better explaination and some examples...
http://www.widescreen.org/aspect_ratios.shtml
topmba
Thank you all. The film is indeed more cinematic in Widescreen. Another flaw I noticed in DIRTY ROTTEEN SCOUNDRELS was that everyone looks pink. It must have been a bad transfer from NTSC to PAL. CABARET is not anamorphic and has sharper edges.
I would say the craze for 2.35:1 is to enable the films to fit into a single DVD. I only know of THE GODFATHER II spanning two DVDs in the Trilogy edition.
figrin_dan
I think you mean film to video.
Also posted by topmba I would say the craze for 2.35:1 is to enable the films to fit into a single DVD.
2.35:1 has been used for decades, dvd only came out in the 90's
Kevo
:confused:
Like figrin_dan says,
2.35:1 is an old aspect ratio which dates back to the 50s.
Mainly Hollywood as European filmmakers are more fond of the 1.85:1 AR.
Nothing at all to do with DVD, just the Director's preference.
I think you'll find a lot of older films are actually 2.40:1 or even wider
It's normally used with 'scope' films (i.e. the ratio is obtained by means of an anamorphic lens rather than matted), but is common to be used with the open matte process these days.
Personally I prefer this wider AR. It looks more 'cinematic' than 1.85:1
topmba
Yet films broadcast on TV are usually 1.78:1 (16:9). The point being to fill as much of the display screen as possible.
Unfortunately a 2.40:1 DVD zoomed up to 16:9 looks awful on my 36" Tosh, using a Tosh sd-330 player.
Kevo
But a 2.40:1 film watched at it's correct AR will look fine on your 36" WS TV....borders and all!
Some broadcasters do crop ws films to fit 16:9...(SHAME ON THEM :nono: ) so as not to upset 'the masses' :rolleyes:
figrin_dan
Shame they can't add another option to the boxes.
16:9
4:3
4:3 letterbox
OAR
Similar threads
Trending threads
