lovegroova
Hi all,
I have had my old Beamax M-Tensioned happily installed and running for many years now, but have recently moved house.
I have got it set up to work with a Nice TT6 control unit so it can be triggered by the projector switching on. All good so far.
However, changes in the setup means I need the screen to roll out less than before, and also, the motor is not cutting out when the screen rolls in. I have a sparate remote so fortunately can stop the motor using that.
I have the attached instructions, but turning either of the allen keys (in either direction) seems to make no difference at all.
Any help will be warmly welcomed, thanks. Is it worth trying to remove the end panel and having a look, or is that likely to make things worse.
