old 32pf9986
Discussion in 'LCD & LED LCD TVs Forum' started by brunj, Sep 2, 2005.
Tags:
  1. brunj
    brunj
    I bought a 32 PF9986 less than a month ago. I am trying to feed it with progressive scan (with pioneer DV585A) as you can see from a previous post. I just read the topic about 32 PF9986 sw version and that the tv should have come with a component cable and a VGA-DVI converter. Not only I did not get anything but the Tv but also did I come to know my sw version is 1.3!!! :mad: :mad: What shoul I do and who should I blame (Philips or the reseller)?? :nono:
    Thank you.
    Sal
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    The retailer will be at fault.
    Insist on an up to date replacement. They'll winge, but you're within your rights...This is not the TV as advertised by Philips.
    Jimmy
  3. erico
    erico
    I have just found a very good price for 32pf9986 (2100€) here in Athens.It is the best price i can get.My question is,is 9986 still worth to go for or should i go for the Sony 'V' series.
    Thanks in advance
