Okay-just bought a PD5200 and need some help...
Discussion in 'Plasma TVs Forum' started by hustler, Sep 9, 2004.
  1. hustler
    hustler
    I want to connect an xbox,sky digital tuner and SONY DAVS550 DVD home cinema system - what's the best way to go about it and to get the best picture on each
    Your help will be appreciated...
    peace
    andy
  2. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Sky Digital
    RGB SCART
    or, RGB SCART into JS Technology RGB -> component convertor
    or, RGB SCART into JS Technology RGB -> VGA convertor
    Xbox
    RGB SCART
    or, official Microsoft High Definition pack with component output (get your Xbox modded to output NTSC with 480p, 720p or 1080i)
  3. hustler
    hustler
    What connections are on the back of the PD5200 then....
    I know there's 1 scart....how many componet output's are there ????
    XboX is already chipped with enigma so should be a doddle....do all UK PAL games convert to NTSC then ?
  4. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    Its Got Two Component In-puts!
  5. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Once your Xbox video output is switched from PAL to NTSC, *most* PAL games output 480p. A handful output 720p and even fewer 1080i.
    Can make this configuration change either by installing a modchip, or using a "softmod" / "savegame exploit". Uncle Google can help.
