Okay - honest opinions, 32" HD LCD..
Discussion in 'LCD & LED LCD TVs Forum' started by wj209980, Oct 24, 2005.
Tags:
  1. wj209980
    wj209980
    Feb 20, 2005
    128
    It was a few months back when I first started looking into the world of big screens and HD TV. Then I had some money issues so it all went out the window, but now I'm back on track again so I'm starting the hunt all over again..
    So, i've not kept up with things... I would like a 32" LCD TV that is HD ready (I'll be looking at SKY HD when it becomes available, and will most probably get myself an X-Box 360..). So what is the best screen out there for around the £1000 mark? Could go a bit higher if you could convinve me it was worth it :)
    Thanks peeps :D
  2. craynerd
    craynerd
    Aug 10, 2005
    331
    panny lxd52 is around £1050
  3. wj209980
    wj209980
    Feb 20, 2005
    128
    cheers mate - will look into it :D
  4. TJNewton
    TJNewton
    Aug 22, 2005
    242
    Planet Earth
    +10
    Toshiba 32WLT58, I've got one and " I'm Lovin It". :thumbsup:
  5. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    I'll refer you to my response to this thread - same rules apply.
  6. Undecided
    Undecided
    All comments subjective and belong to me; this doesn't mean they're right or that you will agree with them!
    I've been looking and lurkng for months. There is now a great selection (IMHO) around the £1K mark - providing you look around and don't just buy from the first shop you go into.
    My wife had quite a lot of input to the choice, because she has quite strong views on "what looks nice" so bear that in mind.
    I narrowed it down to :
    Panasonic LX32LXD500
    Toshiba 32WLT58
    Sony KDLS32A12
    Sony KDLV32A12
    and then the Panasonic LX32LXD52 suddenly entered the frame.
    I think Panasonic have spoilt the styling of the LXD500 over the non HD LXD50. It looks tattier and it's bigger because the speakers have been moved from the bottom to the sides. So out it went.
    The LXD52 suddenly appeared and seems to be an LXD50 with HD input. The styling is the same as the LXD50 so is 'better' than the LXD500. It lacks the 500's SD card input and something else I forget, but it's £400 cheaper than the 500.
    Sony seem to have really upset dealers; I couldn't get a good word about these sets (you will find people going into ecstasy in this forum about these sets, so somebody obviously likes them) because they all said that the panels were made by Samsung and one paid a heavy premium for a Sony brand. One dealer in particular was scathing about the spares situation re Sony. So, although the sets are beautiful to look at, I didn't get the S32 and the V32 is still nearly £1500 from internet dealers.
    So I (we) went for the Toshiba 32WLT58. Wife loves the styling (Tosh call it picture frame) because it has a slim frame, in a grey/silver colour and it's small - 32 is 800mm wide. Has 2 HD inputs and lots of other connectivity.
    Took delivery of mine this morning - set up v. easy and 5mins later everything tuned in. Picture looks great (although it will need tweaking but being a newbie there are so many picture options I'm hoping to get some starter for 10 settings from somewhere) and I can't see any stuck pixels. It cost £1089 from TV & Video Direct (I have no connection with that company); ordered last Friday and arrived today.
    Other people swear by the Samsung which is a couple of hundred cheaper I think.
    However, there is only one way to choose, really and that is to make a short list and then go and have a look and DON'T be put off by the dreadful displays you see in shops like Comet and Curry's. My local John Lewis not only had dreadful pictures on all its TVs but it had dreadful staff as well (with one notable exception)
    So - decide on a short list, go and look and don't be swayed by the slippery tongues of the salespeople.
    Good luck
  7. Chris White
    Chris White
    sammy 32" from waratah? £800ish?
  8. wj209980
    wj209980
    Feb 20, 2005
    128
    thanks for all the tips guys..
    looks like i'm gonna have to research the sammy 32", the panny LXD52 and the Toshiba 32WLT58.........
  9. mjw123
    mjw123
    Apr 21, 2004
    1,302
    48
    +32
    Sammy looks the best - just ask your wife !!
