Ok to use 1x-8x Speed DVD-R on DMR-E55?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Senrap, Mar 16, 2005.
  1. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    In my ignorance I have bought 50 of these from Makro ( 2x25 spindles for the price of 1). So far 3 recordings with no problems.
    By using these discs, can I damage the machine or is is it just a case of possible poor or failed recordings. If the latter I guess I will just have to run with it?
  2. Ryu
    Ryu
    Dec 9, 2004
    252
    +23
    I have used 2x, 4x, and 8x discs to record on with my Panasonic E65 and had no problems. They certainally won't damage your recorder.
  3. DVD-RAM
    DVD-RAM
    As 4x discs are becoming hard to find, Panny themselves have told me that 8x discs are fine.
    I am halfway through a batch of 50 8x Maxell with not one failure (yet!)
  4. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    Thanks Ryu & DVD-RAM for your replies.
    I thought I had read a post a while ago saying 8x would be ok but I couldn't find it.
    Strangely Panasonic told me they recommend 4x as 8x "may not function correctly".
  5. adrianl
    adrianl
    Zero problems so far with Imation x8 discs, recording on E85. The manual implies that up to x32 are OK which seems pretty future-proofed!
  6. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    Thanks Adrianl, but the E55 operating instructions only refer to 4x- speed for DVD-R.
  7. maldonian
    maldonian
    Nov 25, 2004
    919
    43
    +91
    The 32x in the E85 manual is the dubbing speed when 8 hour EP recordings are high speed dubbed to 4x discs. (See the table towards the bottom of page 35 in the manual.)
  8. ptek
    ptek
    Unit will handle x8 media, it wont ofcoarse record at that speed, current drive firmware for E55 is now J131.
  9. HMHB
    HMHB
    Nov 11, 2001
    27,518
    Nottinghamshire
    +6,438
    It may depend on the brand of media as well, but good quality 8x discs are fine with the E55 and E85.
  10. clawson
    clawson
    I ordered a hundred x4 (ritek G04 dye, printable) discs from BigPockets but they actually sent x8 (G05) discs. Used about 40 in the E55 so far without any problems.
  11. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    571
    28
    Manchester
    +32
    Thanks guys!
    You have answered my question before I posted.
    Umu
  12. Senrap
    Senrap
    Nov 19, 2004
    126
    London
    +8
    My requirements are very simple, record and view and then hopefully view again some day. So it seems x8 media will be ok for me despite Panasonic's advice to use X4.
    As far as good quality media is concerned, the x8 discs are branded as Sigma which appears to be Makro's own label.
    As I have said before 3 out of 3 successful recordings so far.
    I would be interested to know if anybody else uses these and with what degree of success.
  13. interstellar
    interstellar
    Dec 10, 2005
    2
    Has anyone used Philips 1-8x dvd-r's on the Panasonic DMR-E55?
    I know it accepts Philips 1-4x dvd-r's.
    After reading lots of forum posts I'm almost certain they will be ok although the DMR-E55 manual only mentions 1-4x disks being compatible :confused:
    It would really help to hear what others think first. I'm not bothered about the recording speeds, just as long as they work. They're still in their packaging at the moment so i could exchange them at the shop. What would you do?
  14. HMHB
    HMHB
    Nov 11, 2001
    27,518
    Nottinghamshire
    +6,438
    I've used Verbatim 1-8x and Taiyo Yuden Unbranded 1-8x on my E55 with no poblems, but can't comment specifically on the Philips ones.
