OK to run 2 sets of speakers off same set of terminals?
Discussion in 'AV Receivers & Amplifiers' started by wyerd, Jan 7, 2005.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    Is it OK to do this, or will it bugger my amp/receiver? What sort of audio levels would I get? Any other thoughts?
    Cheers,
    David.
  2. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    558
    28
    +25
    i don't think it is recommend. that said you can bi-wire using the same terminal so maybe its possible
  3. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Bear in mind that if you run the speakers in parallel,you will effectively halve the impedance seen by your amplifier,and whilst some amps are fine with 4 ohm loads or less,some are not,and either damage,or overload protection may occur.
    Bi-wiring is not the same generally speaking,as the amplifier still sees the same overall load in terms of impedance,via the speaker's crossover.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  5. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Run another pair of speakers off the "B" set. One goes to kitchen, the other to the lounge. Or is there a better way?
  6. KingOfGondor
    KingOfGondor
    Dec 30, 2004
    558
    28
    +25
    if you have two pairs of terminals the you can have speakers in the lounge and kitchen. you should be able to switch the speakers and have A or B, A+B
  7. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    A is already being used in the Plasma room!
  8. bobwylie
    bobwylie
    Dec 27, 2004
    10
    Kirkcaldy
    If A is used by your "plasma room", then that would leave B free for your kitchen run, or are we missing something...
  9. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I also need audio in the lounge (yet another room!)
  10. bobwylie
    bobwylie
    Dec 27, 2004
    10
    Kirkcaldy
    my apologies. I knew I missed something
  11. the mechanic
    the mechanic
    Nov 30, 2003
    1,193
    Wrexham,North Wales
    +52
  12. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I think I can do what I want by using the amps A B switch for the passive speakers in the plasma room and the lounge. Then I can run a pair of active speakers off the PC's sound card (M-Audio 2496) in the kitchen - in effect zoning it.
