I think you call them butterfliesMalabbey said:Can't remember the name of them but you need the type of fixing that when you put in a screw, 'wings' come out and fix in behind the plasterboard.
Anim said:Thanks guys
I might go out and get the ones falwood suggests. I did see them but didn't understand how they worked
I did buy some of these tho...
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=100067&ts=33159&id=18266
Anim
Anim said:Ahh, and for some reason they require a 9mm drill bit. Have you ever tried to buy a single 9mm drill bit?
I went again and all the ones you suggest have small screws that look like they would slide in and out the projector bracket. I wanted to find one with a wider screw that looked like it would happily hold the pj up.
I've spent around 10 quid on screws so far lol but i want to get it right![]()
