Ok so i just got my HD5
Discussion in 'Headphones, Earphones & Portable Music' started by RobThePyro, Sep 8, 2005.
  1. RobThePyro
    RobThePyro
    Hi guys i just got my sony HD5 yesterday, I love it to bits :clap: :thumbsup: , I have done the volume hack, have firmware 1.2 and downloading SS3.2 at the mo. I also have a remote in the mail... Wat other things can i download? is there a way i can transfer songs to and from my HD5 without SS3.1/3.2 and still play them, can i use music match jukebox?
    Thanks for the help guys
    Rob.
  2. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    Congratulations on Your new Gadget ;)
    Unfortunately U can't transfer songs to player without using SS (well U can, but they won't be recognised by player ;) )
    Regards
  3. recsnmisc
    recsnmisc
    Jun 15, 2005
    188
    Portugal
    Congrats on getting the best mp3 player out there! And welcome to the NW-HD5 Forums..errrr AVForums.
    You're stuck with SS. It's great once you get used to it. SS 3.2 is very good too, great improvements in terms of stability plus new atrac3 bitrates are a nice addition.
  4. Tomdale
    Tomdale
    Aug 7, 2005
    177
    How do you check what version of firmare is on the HD5 then? Where can I download updates from?
  5. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Insert AC power.
    Options > Initialize System > Update Firmware
  6. recsnmisc
    recsnmisc
    Jun 15, 2005
    188
    Portugal
  7. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
  8. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
  9. Buzku
    Buzku
    I just got mine too. Do I have to install driver for player to use SS 3.2 that I downloaded and installed ealier today?
    E: SS says that the player must be initialized, whatever it means.
    E2: I installed all the drivers that I could from cd, still SS or Vaio Music transfer don't regonize my player.
    E3: Okay. So I guess I have to initialize my player from the player's menu? Does it format everything else than system files on player? So its safe?
  10. RobThePyro
    RobThePyro
    Thanks for the help guys, my dad is the sony spares and accsesories agent for our city, so he is going to get me a leather case soon and a remote, damm i hate SS it sucks... thanks guys
    Rob.
  11. spawn_e_git
    spawn_e_git
    Sep 9, 2005
    30
    I tried to update the firmware as the HD5 I brought today is V1.0 but I copied the folder 'HDFWUPG' with the downloaded file in it but when I try and update, the unit says No File For Updating Firmware.
    I tried putting the folder in the root of the HD5 and the OMGAUDIO folder.
    Any ideas?
    EDIT EDIT EDIT............
    I copied the whole folder over instead of the file. :oops:
