OK, so here are my 32" lcd final choices!!!
Discussion in 'LCD & LED LCD TVs' started by craynerd, Aug 14, 2005.
  1. craynerd
    craynerd
    Aug 10, 2005
    327
    OK, i have around 1k to spend but i can up it to £1300 max. So after all my questions, here are my final three:
    Panasonic LXD50 - no HD but a nice TV ( £1070 (best online price i can find)
    Sharp LC-32P50E - HD ready!! only £912 !!!! seems good value but hows the quality?!?!
    Philips 32PF5520D - HD ready!! and £950 !!!!
    So so so....the question is, is the panny lxd50 much better quality but without the HD, or are both the sharp and philips good quality and HD THEREFORE genuine good value!!!???
    Ahhh way to much choice, i`m gonna start getting board in a bit and just go out and by the panny lxd50 getting fed up with the descisions!
    THEN the questions arises - well if the sharp and philips are doing a 32" HD ready tv for £950, what extra am i getting from the top two contenders of the panny LXD500 at £1400 and JVC LT-32DS6B at £1350 !!!!!!
    PLEASE PLEASE HELP like i say, i`m getting really frustrated and don`t know what to do! :lease: :lease: HELP
    Chris
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    If you plan on getting a TV for HD, then you can knock the Sharp off the list. It's one of their PAL optimized panels (lower resolution than HD). So - it looks like you're left with the Philips.
  3. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    if reliabillity is a concern i would knock philips off the list,
    so choice of panny or sharp, tough one, but your own opinion on picture quality is what really counts, i have a sharp and the picture is superb,
    and saving nearly 500 quid by buying the sharp would also help me in making my decision, why i went for sharp and not the tosh, plus reading the reviews sharp come out favourably
  4. craynerd
    craynerd
    Aug 10, 2005
    327
    lol, conflicting posts! ...so is the Sharp not really HD ?
  5. peahead
    peahead
    Dec 14, 2002
    2,809
    St.helens
    +262
    The sharp will show hd it will just downscale it to the sharps lower screen resolution but i doubt you would tell much difference.
  6. craynerd
    craynerd
    Aug 10, 2005
    327
    with regards to quality, if you were to line all three against a wall which would come out the best without using HD?
    Also you talk about the sharp downscaling the HD, would it still be better quality than the panny lxd50 without hd at all ?
  7. peahead
    peahead
    Dec 14, 2002
    2,809
    St.helens
    +262
    I think the sharp would look best with normal tv id go for the sharp out of them three.
  8. craynerd
    craynerd
    Aug 10, 2005
    327
    lol, thanks peahead, i have to ask you this since you have responded twice to this post, but to confuse me even further...with a budget of £1000 or just over, what would u go for, full stop?
  9. Scuba_doo
    Scuba_doo
    you can get the Panasonic Tx32lxd500 for £1400
    realise you're at top end of budget but at least you're "future proofing yourself" for a few years..
  10. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Definately cross the LXD50 from your list if you intend keeping the TV for 5+ years and then go and see the others for yourself.
    If my max budget was a £1000 for a 32 inch screen I would go for the Sharp.
  11. peahead
    peahead
    Dec 14, 2002
    2,809
    St.helens
    +262
    Honestly it would be between the new sharp screens or the new sagem 32" lcd tv.
  12. Faust
    Faust
    Dec 21, 2002
    1,820
    UK
    +30
    Also look at the Philips 32PF7520D this is a new panel, has pixel plus which the 5520 doesn't, has an integrated Freeview tuner is HD Ready and gets a 5 star PQ rating. I have auditioned this panel and was most impressed, will cost you around £1200 - £1300
