OK Smart Guys,another PC question
Discussion in 'General Chat' started by Drd, Jan 18, 2008.
  1. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    I'm not the best at keyboards,I cannot type and look at the screen at the same time, and occasionally I LEAVE THE CAPS LOCK ON BY MISTAKE!Is there a way of returning this to lower case without erasing and retyping it?
    Ian
  2. mjn
    mjn
    May 24, 2001
    24,124
    Herts, England
    +12,765
    I don't think so.
  3. Jason_S
    Jason_S
    Dec 11, 2007
    291
    +56
    If you are in a microsoft office application, SHIFT-F3 will do this for you, you will need to re add the caps at the beginning of the sentance, however if you are not in an MS office app then i would recommend copying into one and doing it, give it a try :)
  4. DJT75
    DJT75
    May 6, 2005
    10,895
    +3,831
    Never knew that - damn thing works too :thumbsup:
  5. Jason_S
    Jason_S
    Dec 11, 2007
    291
    +56
    i forgot to mention that you have to select the text you want to change, should be self explanitary, and im happy to help :)
  6. boltoa
    boltoa
    Oct 10, 2002
    920
    2
    46
    Nottingham
    +104
    Depends what application you're using. Some have shortcuts to do it. In MS Word, select text and use ctrl+shft+A to flip case, or the Format/Change Case menu. Other apps may have similar - need to look in help.
    Andrew
  7. DJT75
    DJT75
    May 6, 2005
    10,895
    +3,831
    Outlook?
  8. boltoa
    boltoa
    Oct 10, 2002
    920
    2
    46
    Nottingham
    +104
    Blimey, well late for that.
    The Shift-F3 option will apply sentence case (ie first letter capitalised). Just keep pressing it to cycle through.
    Andrew
  9. Jason_S
    Jason_S
    Dec 11, 2007
    291
    +56
    Definately if word is set to be your email editor, but not if its just set and to HTML and word not ticked as the email editor :)
  10. DJT75
    DJT75
    May 6, 2005
    10,895
    +3,831
    ah-ha, & there lies the problem
    thanks
  11. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    Damn,I've spent years meaning to ask that question,now I know.It's soooo simple when you know how.Thanks all.:)
