Ok Really need help ! (Yes PV500 Question)
Discussion in 'Plasma TVs' started by Italix, Aug 1, 2005.
  1. Italix
    Italix
    Simply question should I buy PV500 or not ?
    I am in no real hurry, just want to buy the correct package. Should I wait for the next version of HD Pannys ?
    Also, is there a Panny HD Monitor version, that is HD ready and if so is it any good (i.e. as good as the PV500). Finally what are your views on just buying a monitor with Sky tuner etc.
    All I want to do is buy a bloody telly !!!! Why is it so hard ?
  2. stevedster
    stevedster
    Jan 13, 2005
    1,128
    48
    Birkenhead
    +41
    No point waiting for the next big thing otherwise you will never get one ! If you are after a 'telly' then yes get the pv500 as going by all i have read and seen it is currently the best plasma out there, comes with both dig/analogue tuners etc...
  3. Kaminsky
    Kaminsky
    Apr 26, 2005
    23
    I agree, I would hold off buying. Theres always something better around the corner.
