Ok Nead Some Help Here Guys Hcpc
Discussion in 'Desktop & Laptop Computers Forum' started by SLIM, Apr 21, 2004.
  1. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    So guys nead ure help here as i know nothing @ all about HCPC
    im looking to builed one cheap as i can and i found this what i wont to know is would this be up to the job.
    ITS job will be just to play MP3'S FILMS like XVID DIVX KVCD and so on.
    [​IMG]
    This is the spec to the pc
    - Supports upto 133FSB VIA C3 Processors
    - VIACLE266 + VT8235 Chipsets
    - Onboard S3 Unichrome graphics
    - 1 x PCI port
    - 6 Channel Audio
    - Front Panel: 2 x USB Ports, 1 x Mic-In Port, 1 x Line-Out(Headset), 1 x IEEE1394 Port, 1 x SPDIF Port
    - Back Panel: 2 x VGA connector, 1 x TV-Out, 1 x Serial Port, 4x USB 2.0/1.1 Port1, 1 x Fast Ethernet 1/10/100 LAN Port, 1 x IEEE 1394a Ports, Line Out, Surround Out & Centre / Subwoofer Out
    - Power Supply 200W (PFC)
    - Extension Bay 5.25*2; 3.5*2
    - Dimensions: 330x215x200 (LxWxH)
    - 2 Years Warranty
    And what ill add is 256MB OF DDR 2100 RAM & A Maxtor DiamondMax Plus9 120GB 2MB 7200RPM HD and a dvd rom
    Its going to be running my 42 inch pd3000 plasma screen any help thanks :lease:
  2. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    come on guys some 1 must know if this would be ok to use
  3. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    West Midlands - Stourbridge
    +332
    SLIM.
    I have not heard much about that machine, so can't comment filly on its performance. You may struggle with the S3 graphics card to get the native resolution of your plasma.
    Would you consider a 'propper' PC based around a shuttle case? They look similar, and allow you more choice with components. It is generaly agreed that ATI Radeon cards are good for custom resolutions.
    Just a thought.
    Rob
  4. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    YES i would go with a shuttle but as i side i dont realy wont to spend a lot i was looking @ this price rangE
  5. Sandman
    Sandman
    Nov 28, 2002
    3,569
    Glasgow
    +1,274
    I am looking for a cheap solution like this too, could you please post a link to somewhere that sells it.
  6. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Pulsar
    I was thinking that i may get a pci gfx card to use in it something like a ATi RADEON 7000 up to a 9600 if thay do a 9600 on a pci card
    are a GF 2''3'4 and maybe look @ the fx rang og gf cards
  7. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    good luck getting a via c3 to cope with divx. They are utter tripe. I couldnt play divx movies at full speed with my via c3 933 overclocked to 1.05ghz/150mhz fsb. I had to lower the quailty just to get them to play smooth.
    It's a shame, baecuase that is one hell of a good looking case:(
  8. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    oh there realy that bad ill leve it then i think look @ getting something als cheap
  9. Sandman
    Sandman
    Nov 28, 2002
    3,569
    Glasgow
    +1,274
    Erhm...link please....
  10. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
