Ok i'm thick
Discussion in 'Blu-ray & DVD Players & Recorders' started by bob1, Sep 4, 2005.
  1. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Ok i'm thick whats the point of playing xvid :confused: ,i've come across this on the net but whats the use of it on a dvd player.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    It's a form of DiVX. You just need a DiVX player capable of playing XVID.
  3. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    :confused: nope still lost,is it when you make your own dvd's on a pc.
  4. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Yeah. Many movies for PC are in avi format, and the MPEG4 compression codec is usually Divx or Xvid.
    If you have a compatible player, you can burn those avi movies directly to DVD/CD and play them.
    Does that help? ;)
  5. justdoit
    justdoit
    Jun 22, 2005
    793
    28
    +53
    The point of xvid/DivX/avi files is they are basically high quality picture and sound files that are substantially smaller file sizes than DVD VOB files. The main point is the obviously faster download electronically of the files owing to the size (700mb-1.4GB typically for avi’s compared to 4.5GB-9GB for DVD VOB's) without much loss in the quality of the material!
  6. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Ok thanks for the replies ,i thought i was missing out on something but unless you download films of the net or make you own home movies its something you won't miss.
