OK if component plugs touch each other?
Discussion in 'Cables & Switches' started by tehn, Sep 29, 2004.
  1. tehn
    tehn
    Hi. Having carefully soldered off 3 fat gold RCAs on one end of my component cable (3 x Belden 1694A), I've discovered that they touch each other when plugged into my projector or DVD player.
    I've put a multi-meter across the outer contacts of the 3 projector sockets (and DVD ones) and they appear all commoned, so I'm guessing it won't be a problem, but wanted to make sure.
    So, is it ok as it is, or should I buy a set of narrower RCAs and redo them?
    Cheers, Niall.
  2. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    It's fine. They are connected together (GND) in most equipment as you have confirmed.
