OK if component plugs touch each other ?
Discussion in 'Projectors, Screens & Video Processors' started by tehn, Sep 28, 2004.
  1. tehn
    tehn
    Hi. Having carefully soldered off 3 fat gold RCAs on one end of my component cable, I've discovered that they touch each other when plugged into my projector (AE300) and DVD player.
    I've put a multi-meter across the outer contacts of the 3 projector plugs (and DVD ones) and they appear all commoned, so I'm guessing it won't be a problem, but wanted to make sure.
    So, is it ok as it is, or do I buy a set of narrower RCAs and redo them?
    Cheers, Niall.
  2. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Prob best to re-post on the cable forum
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Not too sure if I'm understanding this right, but I think you're referring to the outer 'shell' which surrounds the 'hot' central point. If so then you're okay since the shell is the earth and so common to all signals.
  4. tehn
    tehn
    Thanks for reply, and confirmation of what I thought (yes, their outer shells are touching). Now I can get up into the cramped ceiling space to make of the other end - can't wait...
