A
ABP
I hated the slow start speed .and the fan noise was just too much
I also got it in the neck from the wife and kids as they found it very difficult to use... so did i to start with... Clunky would be an understatement.
I Need a good size HD 160G min and it MUST be QUIET and easy to use.
I would like a DV input as i did connect my camcorder but i am unsure if i would chose this option if it meant sacrificing the others.
I would like Freeview tuner although i mainly used the XS34 for backing up and editing both old VHS and more often films from Sky+
I assume all HD DVD recorders can edit out the adverts to a play list and re record them to the HD like the Tosh can?
I found this vey usefull function and often recorded at max bitrate and then edited and saved back to HD at best quality to fit onto a DVD.
Any advice will be usefull i dont want to make the same mistake again.
I have been looking at the Panasonic 60 and the sony 710
