OK, got a DivX compatible DVD player, now what?
Discussion in 'Blu-ray & DVD Players & Recorders' started by english_bob, Apr 26, 2005.
  1. english_bob
    english_bob
    May 10, 2001
    1,486
    Maidstone, Kent
    +168
    Just taken delivery of a Samsung 745
    Downloaded 2 Hidef trailers from http://www.divx.com/hd/ and burnt them to CD-R, but nothing displays on the screen on the DVD player.
    Checked under the File Properties for the 2 trailers, XP says there MPEG Layer 3 (not 4), so I guess thats the issue then.
    Where do you guys get the DIVX files from? I'm looking for a really good HiDef demo that I can use on my new DVD player
    Any links greatly recieved.
    :thumbsup:
  2. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +60
    I play them through my PC. As far as I know there isn't a DIVX player out there that is compatible with the DivX HD format yet.
  3. english_bob
    english_bob
    May 10, 2001
    1,486
    Maidstone, Kent
    +168
    well, that does'nt suprise me. This HiDef thing is a right ballsup. Its never going to sell. Joe Public has just about got his head around SCART lead and an RGB signal, never mind component (and the lack of support of !) / 3 different types of DVI connection / HDMI / HDCP / Progressive / HDDVD / Blu-ray. :thumbsdow
  4. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    You can get Divx HD players ...just not in the UK just yet, Japan / America.
    Per the files u downloaded try using a DVD-RW as the Samsungs are funny about using divx of cds.
  5. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    I have wmvhd and divxhd trailers on my pc. you could always plug your your pc into your tv providing your tv scan support the high resolutions..?
  6. whatdvdplayer
    whatdvdplayer
    I'm pretty sure, though have never used the option as I have no Plamsa/Projector.
    It is a LiteON (I think its a 2001 model - has a Phomaster slot on it
    for looking at digital images)
    It has a PSCAN button on the remote which toggles the number of output lines between:
    NTSC
    PAL
    480p
    720p
    1080I
    Hope this helps.. ( www.liteonit.com )
  7. dean randle
    dean randle
    Jan 9, 2003
    154
    UK (Bromley)
    +6
    I too have the Samsung 745, and it will NOT play the hd clips as the resolution exceeds that allowed by the divx software in the player. Any other regular divx/xvid/avi files play, and look stunning on my regular tv. Try downloading some of the regular clips from divx.com and burn those onto a cd, you'll see how good they can look.
    Dean.
  8. zoro
    zoro
    Jan 23, 2003
    292
    Well, let me ask you can you burn divx files, or avi files on dvdr, e.g? a movie to 4GB or so?
  9. whatdvdplayer
    whatdvdplayer
    You can put divx movies on a dvdr. I have compilations, ie Ringu1,2,0 and eye1,2 Upto six films on on 1 dvdr. Label them DIVX_HORROR1 etc..
  10. zoro
    zoro
    Jan 23, 2003
    292
    What is max you can burn a xvid or divx dvdr, to get the best results, 1,2 0r 4 GB?
  11. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    Zora, whats your question ? I burn a DVD-RW or R to the full 4.7gb no problem.
  12. zoro
    zoro
    Jan 23, 2003
    292
    Sorry NX3, I might not have worded it right?
    If I am to make a 2-2.30 hrs film on XVID and burn on DVD, then keepingXVID file to 4GB will give me better resolution that keeping it 1.5 GB or not?
  13. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,122
    Bristol
    +5,914
    I am not 100% sure but I dont think you can have a single divx file bigger in size than 1Gb, it has to be seperated before that point otherwise when it reaches the 1Gb limit it will just stop playback.
  14. zoro
    zoro
    Jan 23, 2003
    292
    So 7 GB MP2 into 1GB MP4 is the same quality?
  15. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,122
    Bristol
    +5,914
    With the 1Gb limit you want to break the film up into parts, you dont want to try and compress a film which is over 70/80mins into a 1Gb file otherwise you will get nasty quality, what you want is about 800Mb per hour of film so a 2 hour film will be 2x 800Mb files, this should give you good quality.
  16. zoro
    zoro
    Jan 23, 2003
    292
    So, if I rip with dvd decryptor and have it do 1GB segments on 7G movie!! then do I have to convert 1GB each seperately to XVID? pls advise?
    I have done previously a 2 hrs movie for my psp to divx/mp4, to 700-800mb, that looks fine on psp, but is not suitable for big screen tv i guess? Can you pls refer to some resource for guidance?
  17. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,122
    Bristol
    +5,914
    You dont have to convert each 1Gb file, what you do is use DVD Decrypter to extract the film in .vob format and then load those files into a DVD to Divx program, I use a program called AutoGK.
    Once in the program you just select the settings you want including how many files you want it split into, then you just set it running.
    Check out www.autogk.net for more info.
  18. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    The 1gb file limit varies from divx player and your PC. AVI container is generally best to keep under 1gb per file though as not to cause problems either end
  19. whatdvdplayer
    whatdvdplayer
    There is no point encoding a divx file greater than 2x700mb parts, otherwise you defeat the object of DivX. You may as well just burn 1 film as a single DVD format film on 1 DVDR ?
